Battery Registration
Posted 14 January 2010 - 05:00 AM
AS I READ BEFORE ON DIFFERENT FORUMS, THE BATTERY NEEDS TO BE REGISTERED AFTER REPLACMENT.MY QUESTION IS THAT, SHOULD THIS PROCCESS TAKES PLACE
EXCLUSIVELY AT THE BMW DEALER, OR A MECHANIC WITH THE PROPER DIAGNOSTIC TOOL (SCANNER) CAN DO THE JOB?
Posted 14 January 2010 - 11:19 AM
2004 Alpine White 545i SMG -- gone but not forgotten!
Miss you JDN!
Posted 25 February 2010 - 08:26 PM
Posted 25 February 2010 - 08:59 PM
Posted 21 March 2010 - 06:06 AM
pauliehcfr, on 25 February 2010 - 08:59 PM, said:
Sounds like an unintelligent battery sensor. If it is actually sensing anything it should be able to tell the state of the battery right? Why would you have to tell it that it's a new battery? My local dealer gave me all that nonsense too and was trying to tell me that their "intelligent diagnostics" told them there was nothing wrong with my battery even after 3 repeated failures. That "reprogramming" story is their sales pitch to try to sell an overpriced part and labor to gullible BMW owners. Ask to see the diagnostic procedure for battery test and the reset procedure....they couldn't produce either after having my car for a total of 5 days and telling me there was nothing wrong with the battery. I showed them the battery drained to less than 8 volts in just 20 seconds with the lights on. When I did they backed down and replaced my battery under warranty....4 years and 43,000 miles. That was the last time I went to the dealer for anything.
Wanted: Full M-Tech Kit, Quaife LSD, UUC Short Shift, STS Turbo
Posted 21 March 2010 - 07:49 AM
fryeje, on 21 March 2010 - 06:06 AM, said:
What kind of problems were you having with a weak battery? Car would not start, error messages.....
Just want to know what to look for when this thing happens to me.
Posted 21 March 2010 - 09:22 AM
Oh, I'm sorry. Where is your BMW factory training certificate?? That's what I thought. Mine is right here....When they test the battery, it has nothing to do with the intelligent battery sensor. They are actually load testing the battery or checking the specific gravity of the acid in the battery with a separate tool to determine the state of the battery. As far as diagnostics, they probably performed a quick test and recovered 0 faults. The battery fault would register in the DME as well as store all kinds of faults for voltage issues in other control modules. The battery sensor monitors the condition of the battery and adjusts the charging of the battery based on what it detects. An older battery will not hold a charge as well as a new one, therefore it needs to be charged at a slightly higher amperage rate to maintain the same state of charge as when it was new. When you install a new battery, the car does not know this and will continue to charge at a higher amperage rate, therby overcharging a new battery and ruining it eventually. You essentially need to "reset" the battery sensor so that it charges the battery at a lower rate. Just another instance of a Monday morning quarterback who has all the answers regarding pertaining to something they think they have some knowledge about. Your battery was probably crap because it was 4 years old and not maintained well. Batteries typically only last 5 years if they are maintained.
Posted 21 March 2010 - 10:30 PM
Posted 22 March 2010 - 12:30 PM
turboawd, on 21 March 2010 - 10:30 PM, said:
Voltage regulators do not tell that the battery is fully charged. They do just what their name implies....regulate voltage so that the alternator does not overcharge the battery. They maintain a constant voltage output to charge the battery and maintain that voltage so it doesn't overcharge. BTW where did you get your automotive certification from again?
Posted 22 March 2010 - 01:28 PM
Posted 22 March 2010 - 04:12 PM
turboawd, on 22 March 2010 - 01:28 PM, said:
Why would it be correct for the car to assume a new battery was installed? Batteries get disconnected quite often during servicing, etc. Resetting to a "new" battery just because power was disconnected would not be "intelligent" at all...
Miss you JDN!
Posted 22 March 2010 - 05:45 PM
Posted 22 March 2010 - 11:00 PM
Help
