5 Series Forums: HID Fogs, Interior LEDs, License Plate LEDs DIY - 5 Series Forums
Jump to content
  • (3 Pages)
  • 1
  • 2
  • 3
#1 User is offline   brabusw209amg
  • Specialist
  • PipPipPipPipPipPipPip
  • Group: Contributors
Posted 12 June 2009 - 12:17 AM
I'll be doing a DIY since many people have questions on how to remove. By starting this thread, I'll be sure to be posting pictures within a couple days. But for now, feel free to ask any questions you may have. Here's some hints for the time being:
HID Fogs:
- Passenger Side
Remove the screws that hold the fender well to gain access to bulb
- Driver Side
Remove screws AND pull down the bottom flap to gain access since the windshield fluid reservoir is in the way
- Mounting Ballasts
Can mount ballasts anywhere since they are waterproof but you can always zip tie it to keep the ballast clean and free of dirt.
Interior LEDs:
- Use the factory BMW screwdriver to pry down the rear dome.
- For the front dome, pry open the control panels (where the air bag, sunroof, SOS buttons are) first and use your hand and push down the entire console.
- Use your hands to remove the plastic cover. When installing ALL LEDs, if it doesn't light up, flip it around since LEDs are polarized.
- When installing panels, make sure the metal connections are connected to the sockets or else it would not power up. Slide the connections a bit to the outside BEFORE installing into the socket.
- Try not to pull ANY of the housings out. Turn the lights off and remove the bulb. Becareful! Bulbs are HOT.
- May have to slightly bend connections to fit the bulbs.
LED License Plate Lights:
- Stick a screwdriver in the slot. Keep this in mind: "YOU ARE AIMING TO SLIDE THE HOUSING TO THE RIGHT."
- When the screwdriver (once again, use the BMW screwdriver) is in, slide the housing to the right.
- Hold the housing to its right-side position with your right hand. Take your left hand and pry the left side of the housing down with your fingernail.
- It should not pop out freely and easily. Do not use too much force or you end up like MANY of us cracking the housing and end up either replacing or my favorite: crazy glue.
寶馬 aka Precious Horse - ILB LCI M5; Audi Allroad; Scion xA - New Pix Will Be Up Soon
Posted Image
REV IT NYC Partial Product Line.
PayPal or Google Checkout to brabusw209amg@gmail.com with confirmed address.
LCI HID Angel Eyes - $230 shipped: Click Me!!!
HID Reverse Lights - $200 shipped: Click Me!!!
D1S ($120) or D2S ($80) upgrade bulbs for Low Beam Bi-xenons: Click Me!!!
HID Conversion Kits For Fogs, Low Beams, and High Beam - $160 shipped: Click Me!!!
Sprint Booster V2 - $300 shipped: Click Me!!!
Stick & Sigs Package Deal - $85 shipped: Click Me!!!
MTEC V2 Pre-LCI Angel Eyes SPECIAL! - $135 shipped: Click Me!!!
MTEC License Plate Lamps - $75 shipped: Click Me!!!
RDash License Plate Lamps - $55 shipped: Click Me!!!
License Plate Replacement LEDs - $35 shipped: Click Me!!!
Interior LEDs with LED panels SPECIAL! $105 v1.5, $130 v2.0: Click Me!!!
Call or SMS at 347-788-8681 for inquiries. No unknown calls. I do not answer them. Thank you!
#2 User is offline   Epic
  • Senior Member
  • PipPipPipPip
  • Group: Members
Posted 12 June 2009 - 07:07 AM
ello mate, could you tell me the bulb size for the fogs? also do you think they would still look good with perhaps philips bright blue bulbs insted of hids
2005 530d M Sport Carbon Black!
Built Apr 2005, CIP: 21.00.00 March-06
/// Angel Eye upgrade /// Subwoofer and Amp Install /// Black Kidney Grille /// Dark Tints all round /// De-Badge ///
#3 User is offline   brabusw209amg
  • Specialist
Posted 12 June 2009 - 06:18 PM
it will never look the same with just regular halogen bulbs. You have to use HIDs for the full brightness. Your car's foglights are 9006. :D
Posted Image
#4 User is offline   brabusw209amg
  • Specialist
Posted 13 June 2009 - 02:12 AM
LED Interiors Install:
Removal of Top Trunk LED
Posted Image
Removal of Bottom Trunk LED
Posted Image
Removal of Bottom Door LEDs (Same process for all doors - BMW might have installed the housing differently so u may have to pry it down either on the left or right side. DO NOT use too much force. Ur fingernails should be enough power)
Posted Image
Removal of Rear Upper Console (LED Panels are bright huh? Stick a screwdriver in and pry down)
Posted Image
How To Unplug The Housing (Picture works for both front and rear dome lights)
Posted Image
Posted Image
#5 User is offline   brabusw209amg
  • Specialist
Posted 13 June 2009 - 02:13 AM
Crack Open Plastic Cover to Gain Access to Center Bulb for Panels (Pictures works for both front and rear dome lights; If one side is hard to crack open, try cracking it from the other side)
Posted Image
Pull The Bulb Out And Replace It With The T10 Panel Adaptor
Posted Image
T10 Panel Adaptor IN!
Posted Image
Plug The Panel Into The T10 Panel Adaptor
Posted Image
Panel LED Plugged In
Posted Image
Remove The Double Side Tape And Stick It On Securely Into The Center
Posted Image
Posted Image
#6 User is offline   brabusw209amg
  • Specialist
Remove The Socket And Pull Out Old Bulb And Replace With LED (Test if it turns on. If it doesnt, unscrew the socket and rescrew it after flipping it 180 degrees)
Posted Image
Panel And Map Lights Installed! (Gotta love it! Nice and bright during the daytime too)
Posted Image
Removal Of Electronic Controls Panels That Consists Of SOS Light, Sunroof Light, etc First (Pry down slightly with screwdriver and pull down with hand)
Posted Image
Posted Image
Once Removed, Push Down Console To Remove Front Dome Light
Posted Image
Posted Image
Removal Of Window Visor Panel
Posted Image
Posted Image
#7 User is offline   brabusw209amg
  • Specialist
Posted 13 June 2009 - 02:18 AM
Check out this thread for more info: http://forums.e60.ne...pic=65064&st=75
$100 special INCLUDING panels!! Regular $135.
Posted Image
#8 User is offline   brabusw209amg
  • Specialist
Posted 13 June 2009 - 02:30 AM
HID Fogs Install
Turn Wheel All The Way To The Right
Posted Image
Remove The Two Screws (Red Circles)
Posted Image
Remove The Screw That Attaches The Bumper And Fender
Posted Image
Remove The Inner Screw (Red Circles)
Posted Image
Pull The Fender Well Out (Reveils the windshield wiper fluid in the way)
Posted Image
Push The Bottom Plastic Piece Down
Posted Image
Posted Image
#9 User is offline   brabusw209amg
  • Specialist
Pull the Plastic Piece Down Like So
Posted Image
Unscrew the Factory Bulb
Posted Image
The Strobe Free, Flicker Free, Error Free HID Ballast!!!!!!
Posted Image
Plug And Play Everything Together (Make sure positive to positive, negative to negative)
Posted Image
Posted Image
Posted Image
Posted Image
#10 User is offline   brabusw209amg
  • Specialist
Test The Bulb (DO NOT look directly at the light)
Posted Image
Everything Installed Back And Test How It Looks
Posted Image
Coolbreeze44's Driver Side View With Angel Eyes And Fogs On
Posted Image
Comparison Of Stock Fogs And 6000K HID Fogs
Posted Image
Removal Of The Passenger Side Is The Same Way. 4 Screws.
Posted Image
Completion!
Posted Image
Posted Image
#11 User is offline   brabusw209amg
  • Specialist
Posted 13 June 2009 - 02:37 AM
$145 shipped for HID fog lights
http://forums.e60.ne...showtopic=65593
Posted Image
#12 User is offline   suppers
  • Member
  • PipPipPip
  • Group: Members
Posted 13 June 2009 - 08:26 AM
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Completion!
Posted Image
Great DIY. Thanks for the LED interiors, they're bright!
#13 User is offline   brabusw209amg
  • Specialist
Posted 13 June 2009 - 03:05 PM
shouldve came stock like that but I'll be out of business. LOL
Posted Image
#14 User is offline   brabusw209amg
  • Specialist
Posted 16 June 2009 - 12:51 AM
i might put LED panels in the under door lights, trunk lights, and footwells. I'll see how that goes. keep u guys updated!!!
Posted Image
#15 User is offline   flint
  • Senior Member
  • PipPipPipPip
  • Group: Members
Posted 16 June 2009 - 10:04 PM
Great DIY with pics! I bought and recently installed the full interior LED set with panels. Easy install (would have been even easier with this thread) and love the look and quality. The license plate LED's look great as well. Also got great support from Brabusw209amg when I had a slight issue with license plate LED's. He backs up what he sells!
2004 545i Black Sapphire Metallic|Black
Options: Sport Package|Premium|Cold Weather|6-speed|Logic 7|Active Steering|Smoked LED Sidemarkers
Flat Black Grill and Badges|M5 Spoiler|20" Vertini Hennessey Wheels|Charcoal Filter Deleted|Full LED Interior Lights
LED License Plate Lights|Smoked Tails|Euro Style Overlays
Posted ImagePosted Image
Share this topic:
  • (3 Pages)
  • 1
  • 2
  • 3
5 Series Information Network
