Here are my step my step instructions on how I lower a 7 series. This is just to show you whats involved. This is not meant to say that this is the correct or proper way, so dont criticize me on this one. If you do not have the confidence or tools to do it, just pay the usual $400 - $500 installation charge and leave it to the pros. I am not responsible for you messing something up, or hurting yourself. Save yourself the headache and find a good qualified shop to do it for you.
Thanks Cuzimack for letting me take pics under your car during the installation.
Air tools highly recommended. You can do it with hand tools, but its alot more work, and time consuming.
I started on the drivers side front corner first. Spray all the visable nuts that are attached to the suspension with some WD40. This will make things a little easier.
Step 1.
- Do this on a level surface. The use of a lift is prefered. If you do not have access to a lift, put your car on some strong jack stands. DO NOT WORK UNDER A CAR THAT IS JUST SUPPORTED BY A HYDRAULIC JACK WITHOUT JACKSTANDS, OR USING YOUR OEM JACK. You can seriously hurt or even kill your self. The OEM jack sucks!
Step 2.
- Pull of the front wheels. Using a 21mm socket, remove the nut that is holding the outer tie rod that is attached to the spindle. The tie rod is the piece that connects your steering rack and pinnion to the wheels. Using a ball joint remover or breaker, press out the ball joint. It should look something like this. DO NOT damage the rubber boot that covers the ball joint.
Sign In
Register
Help
MultiQuote
