5 Series Forums: ACM - Accessory Control Menu Plug and Play DIY - 5 Series Forums
Jump to content
  • (2 Pages)
  • 1
  • 2
#1 User is offline   bruce_miranda
  • Specialist
  • PipPipPipPipPipPipPip
  • Group: Contributors
Posted 19 May 2008 - 04:32 PM
I'll start this DIY by putting pictures of the finished product first to get you excited :-)
Attached File  DSC00265.JPG (159K)
I installed a Nextbase Tablet DVD on a Brodit mount in between the front seats. This is connected to a OEM video plug in the center console that feed the ACM Video input. I made custom cables for the Tablet because I hate to see long cables wound up for no reason. Even the lighter socket charger is custom made because the standard plugs were too long and I feared that it may break while passengers get in and out of the car. Also the jacks used on both sides are the right angled plugs to minimise the space needed. Now the only thing I need to find is a neat cable wrap instead of the cheap looking tape I've used at the moment. I have another Nextbase DVD player for sale if anyone is interested.
Attached File  DSC00266.JPG (159.29K)
That way both the front and rear can watch the video. The remote for the DVD works quite well even from the driver's or passenger's seat.
I used the following instructions although my ACM was part 65500431544.
Attached File  BMW_ACM.pdf (1.4MB)
After you disconnect the Negative Terminal of the battery. Start by removing the trim.
Attached File  DSC00178.JPG (125.06K)
Then the AC controls.
Attached File  DSC00179.JPG (131.42K)
Then the CCC
Attached File  DSC00180.JPG (140.44K)
Then the center trim.
Attached File  DSC00181.JPG (130.75K)
Build a custom power splitter instead of following BMW's instructions and that way you can get the solution completely plug and play.
You'll need the following parts for this
1 x UNIVERSAL SOCKET HOUSING UNCODED 3 POL. 61138377072
1 x UNIVERSAL PIN TERMINAL UNCODED 3 POL. 61136931929
2 x PIN-CONTACT 0,75MM 61130006664
2 x BUSHING CONTACT 0.75MM 61130006663
Attached File  DSC00182.JPG (139.61K)
Use the module stand behind the front fuse box to house the CAN interface. Just disconnect Pin 2 and Pin 19 from the CAN interface plug and video will work at any speed.
Attached File  DSC00183.JPG (48.72K)
Connect the Aux connections behind the CCC. Here note the BMW instructions have an error in the colour coding of the AUX wires and that will mix your Left and Right Channels. So follow the pin numbers and you'll be fine.
Attached File  DSC00184.JPG (152K)
House the ACM unit above the CD Changer.
Attached File  DSC00201.JPG (152.75K)
I didn't route the Video input cable all the way to the boot as mentioned in the instructions because I had planned to use a DVD tablet. So instead I routed the plug to the center console and then connected it to an OEM Video plug unit.
You'll need the following parts for the video plug.
1 x PLUG SOCKET AV 61316930560
1 x UNIVERSAL SOCKET HOUSING UNCODED 6 POL. 61136909058
6 x BUSHING CONTACT 0,2- 0,5MM 61130005197
If you want to connect an Aftermarket DVD player you will need the following parts.
1 x UNIVERSAL SOCKET HOUSING UNCODED 18 POL. 61131383852
5 x BUSHING CONTACT 0,2- 0,5MM 61130005197
And a 3 RCA socket cable or appropriate connect (the red, white or black and Yellow cables)
In the 18 POL. 61131383852 plug put your contacts 61130005197 in pin positions as follows
Pin 5 - Audio L +ve
Pin 6 - Audio R +ve
Pin 7 - Audio Ground -ve
Pin 8 - Video +ve
Pin 9 - Video Ground -ve
Then connect the other ends of the wires of these contacts to the RCA plugs using the Red for right, white/black for left and the Yellow for Video.
Connect this custom cable that you have just made to Connector A10 on the ACM wiring harness. This will give you a Video input.
Also I have a RHD car and you cannot follow the instructions as given by BMW for the LHD. So that is the reason I had to choose alternate locations for the CAN and ACM unit but the plus side is that I didn't have to open the driver's side of the car at all.
Put everything back and pray that it all starts :-) There is a good reason why this DIY is not as detailed as my other ones. If you cannot understand what is done based on these pictures don't bother doing this at home. There are too many things that could go wrong or you could damage while trying this and its best to pay a dealer for the installation.
BMW E60 520d SE Saloon M47 2.0d, Titanium Grey II, Grey−Dakota Leather, Visibility Package, Media Package, Through Load System, Lumbar support − fr seats, Automatic Air Conditioning−Advanced, High beam assistant, Hi−Fi Loudspeaker system, Heated Front Seats, Heated Steering Wheel, Extended Voice Input Retrofit, Auxillary Input Retrofit, DMS, 19" 172M Sport wheels and spare, HTC WM5 phone cradle DIY, Rear Power and Aux sockets DIY, Footwell lights DIY, Mic Mute DIY, Boot parcel net DIY, LCI Tail-lights DIY, Subwoofer and Aftermarket Amplifier DIY, BMW 0+ Car Seat Travel System DIY, Dension Gateway500 DIY, Dension IVE1000 iPOD Video DIY, ACM Retrofit DIY, Bootlid Reverse Camera DIY, Door LEDs DIY, Illuminated Shift Knob DIY, Mirror Puddle lights
Brand New M Tech Rear Bumper for Sale + Free V6 Cables
#2 User is offline   Uzzle
  • Specialist
Posted 19 May 2008 - 04:36 PM
Whaaaaat! Thats dope! I always wanted to watch a dvd from the front screen or install a camera so I can see when I reverse.
Posted Image
08' 528i LCI Jet Black l Black Dakota Leather l Premium l Navi l iPod l Logic 7
Mods: M-tech front & Skirts l M5 Rear l M Trunk Finisher LCI l Hamann Style Splitter l Custom Quad with 3.5 tips l VIP Modular VR-03 20x9/10.5
l Bilstein PSS9 Coilovers l HID Low Beams & Fogs 6000k l LED Turn Signals & Side Markers l LED License Plate l 20% Tint all around l Clear Bra
#3 User is offline   imposss
  • Senior Member
  • PipPipPipPip
  • Group: Members
Posted 19 May 2008 - 05:27 PM
WILL IT WORK WHILE DRIVING?
545i Saphire Black/Auburn Brown, SMG, HUD, Navigation, Logic7, Sunshades, All Packages, PDC.
MODS:Carbon kidney grilles, Charcoal deleteted, 5% Back 20% Front tint, Carbon interior, Mtech 6000k HID fog lights (no error msg.)
AIB V3..............................................................................
Previous rides:
2004 Infiniti FX45 sold...
2001 Acura CL Type S stolen...
#4 User is offline   Nitrodaze
  • Junior Member
  • PipPip
  • Group: Members
Posted 19 May 2008 - 05:30 PM
Top man bruce. That is awesome :o
520D M Sport Manual, Media Package, Dakota Grey leather, USB, Folding mirrors, Carbon Black.
Someone gotta care about the planet ......
#5 User is offline   bruce_miranda
  • Specialist
Posted 19 May 2008 - 06:19 PM
Yes. just disconnect Pin 2 and Pin 19 from the CAN interface and it will work at any speed.
#6 User is offline   John Photography
  • Specialist
  • View gallery
Posted 19 May 2008 - 06:25 PM
this is awesome!
3 quick questions -
  • how is the video quality on the NAV screen?
  • once installed, the iDrive need any programming by the dealer?
  • what was your final cost in doing this?
Posted Image
Posted Image
#7 User is offline   al_ongvano
  • Elite Member
  • View gallery
  • Group: Senior Members
Posted 19 May 2008 - 07:09 PM
Well done my man. Will this set up works for non navigation system
530I Silver gray with gray leather with Premium Package, Logic 7 Premium sound system with Ipod interface, xenon adaptive headlights, Active steering, Power retractable rear sunshade, Comfort seats and Cold weather package.
Mods:
M5 OEM 166 wheels, Sprintbooster, Rogue 12mm. spacers, ACS pedals, Bilstein Sports Shocks with Eibach ProKit Springs and Brake performance Dimpled/Slotted premium Rotors with Axxis Deluxe Pads, Shadowline trim, LED License plate lights and and 50% Ceramic tint all around.
Former Bimmers:
2000 BMW 528I
1994 BMW 325I
Posted Image
#8 User is offline   pentiumpush
  • Junior Member
  • PipPip
  • Group: Members
Posted 19 May 2008 - 07:23 PM
I also would like to know if this will work on non-navigation equipped e60 cars. How much can I expect to pay for that ACM?
PRECISION TV & ELECTRONICS SERVICE
Quality Service, Reasonable Rates
859-609-2887
#9 User is offline   bruce_miranda
  • Specialist
Posted 20 May 2008 - 02:12 AM
The quality on the Navigation Screen is OK - not great but OK. But that is not the fault of the ACM its just the resolution of the Navigation screen is a bit lower than aftermarket TFT screens. You dont need any programming to get this working, however you must have the AUX option coded in your car in advance because the ACM using the AUX input for the sound. It didn't cost be anything to install and the actual ACM is still not available in the UK. Also I bought my ACM second hand so the price I paid is not representation. But expect to pay between $600 - $675 for the unit and then add installation. Don't get fooled by the 1.75hours install time on the instructions. I'd happily challenge any dealer in the world to install this as per instructions within that time.
Yes you can install it on non-navigation screens. A big thing for pro navigation people to remember is that the ACM will only utilise the middle section of the screen - i think this is as big as the screen in non-nav or business nav cars. I bet its something to do with maintaining image aspect ratio.
You can connect any aftermarket TV or DVD by a simple plug and play modification to the plug but then you wont be able to control these devices via the iDrive. Same with the cameras too - aftermarket works fine.
#10 User is offline   wacopolumbo
  • Elite Member
  • View gallery
Posted 20 May 2008 - 04:24 AM
So this is an OEM part that allows you to watch stuff on the NAV screen? Pretty cool!
Posted ImagePosted ImagePosted Image
2007 525i | Mystic Blue Metallic | Black Leather | Premium Package | Xenon | Steptronic | PDC | iPod | Nav | 20% tint | De-badge | Shadowline Trim | M-Tech Body Kit | ACS Rep Roof Spoiler | ACS Rep Trunk Spoiler | Black ACS Rep Quad Diffuser | 3D Design Rep Splitters with Black Tips | Remus Quad Exhaust | ACS Rep Tips | Color Matched Roundel Stickers | Black Kidney Grills | 124s for Winter | 121s for Summer | Sprint Booster | OEM Stainless Pedals | M-Tech Footrest | Wood Shifter | Wood e-Brake Handle | Wood Steering Wheel Inserts | Wood Steering Wheel Roundel Stickers | Zenon Interior Light Kit | Angel Eye Light Upgrade | HID Foglights | Clear Sidemarker Bubs
#11 User is offline   bruce_miranda
  • Specialist
Posted 20 May 2008 - 02:20 PM
Correct.
#12 User is offline   al_ongvano
  • Elite Member
  • View gallery
Posted 20 May 2008 - 03:42 PM
thanks for the info. more power
Mods:
Former Bimmers:
2000 BMW 528I
1994 BMW 325I
Posted Image
#13 User is offline   Midget
  • Member
  • PipPipPip
  • View gallery
Posted 24 May 2008 - 11:12 AM
[/quote]
Couldn't agree more Bruce.
I have the same setup but still need to connect the tablet on the armrest to the video out from the ACM. However I would like to make it "smart" I would also like to feed the acm with signal from the tablet (which has a built in DVD player). That way you can watch TV on both monitors (via the DVB T connected to the ACM and can watch DVD via the tablet and have sound over the speakers. I need to figure out how the tablet can provide a signal and reaceive asignal with a simple switch. Any ideas ?
Midget
2004 Black 525i Touring with Beige Nasca leather, Panorama Roof, SMG Gearbox, Navigation Business, Ventilated Comfortseats with Massage (Retrofit !), Heated Steering, Rear Airbags, Alarm (Retrofit), Cupholders, Folding Mirrors with Auto Dip and Memory (Retrofit), Bluetooth, CIP 23.x, ACM Unit, Rear View Camera and Digital TV Tuner (Retrofit), Detacheable Tow Bar (Retrofit), Rear Sun Shades, Bi Xenon Adaptive headlights (Retrofit). Wheels; Winter: 16" style 134 Summer: 18" style 122.
*** SMG Rulez *** don't you just LOVE Launch Control....
Other cars:
* Audi A4 Avant 2009, White with Black Rims
* MG Midget 1971, White with wire wheels
#14 User is offline   rantei
  • Newbie
  • Pip
  • Group: Members
Posted 18 June 2008 - 01:52 PM
Hi Midget, i have a question for you; if i have the Bmw DVB-T connected to the a10 connector of the ACM then i cannot use a generic dvd player or i can connect it to the rca of the dvb-t?? Please help me, thank you.
Michele
#15 User is offline   Boxador
  • Senior Member
  • PipPipPipPip
  • Group: Members
Posted 05 July 2008 - 03:32 AM
Do you know where I can just get the mount separately? Can you please provide some more detail about that? Maybe a picture of how it mounts to the armrest? Your project is hot.
Share this topic:
  • (2 Pages)
  • 1
  • 2
5 Series Information Network
