I lost so much of space when I upgraded to 19" normal wheels because the spare wheel well suddenly had a spare wheel in it when previously it has a whole lot of things.
Some of the things went into the right hand side parcel net but the rest just banged around in the back. Some of those items were the various wipe boxes (i.e. glass wipe, dashboard wipe etc). I thought why don't I have a parcel net on the left. I have see some cars that have a cubby hole on the left and I don't know when you get that option. However this is what I did.
BMW parts needed
1 x B51 7 6 9511 788 - Parcel Net (note this already comes with two clips B51 7 6 951 789 so no need to buy them seperately)
2 x B72 16 1 858 017 - Circlip
1 x 5mm wood drill bit
1 x 10mm wood drill bit
Total time : 10 mins
Best thing would be to remove the left taillight cover when you are doing this.
The net is made for the right side only but if you reverse it and bend the two ends of the fixing rod in the other direction you can make it work for the left side no problem. Simply measure the net rod ends and drill two holes using the 5mm drill on the vertical walls in similar positions to how the right net is attached. Install the net and attach the circlips lightly to the net rods.
Then measure where the bottom clips need to go and then make two holes using the 10mm drill on the floor part of the left taillight cover. Install the two clips and then tighten the circlips. Job done and looks absolutely stock.
Wonder why BMW didn't provide one of each side to begin with.
I'll post a picture later so that you can see it. But this is written to provide you with an idea. Now go DIY.
Page 1 of 1
Retrofit Parcel Net on the Left side of the boot / trunk
Posted 11 July 2007 - 02:55 PM
BMW E60 520d SE Saloon M47 2.0d, Titanium Grey II, Grey−Dakota Leather, Visibility Package, Media Package, Through Load System, Lumbar support − fr seats, Automatic Air Conditioning−Advanced, High beam assistant, Hi−Fi Loudspeaker system, Heated Front Seats, Heated Steering Wheel, Extended Voice Input Retrofit, Auxillary Input Retrofit, DMS, 19" 172M Sport wheels and spare, HTC WM5 phone cradle DIY, Rear Power and Aux sockets DIY, Footwell lights DIY, Mic Mute DIY, Boot parcel net DIY, LCI Tail-lights DIY, Subwoofer and Aftermarket Amplifier DIY, BMW 0+ Car Seat Travel System DIY, Dension Gateway500 DIY, Dension IVE1000 iPOD Video DIY, ACM Retrofit DIY, Bootlid Reverse Camera DIY, Door LEDs DIY, Illuminated Shift Knob DIY, Mirror Puddle lights
Brand New M Tech Rear Bumper for Sale + Free V6 Cables
Posted 12 July 2007 - 02:19 PM
Do you want a Parcel Net on both sides. Then do it!
Share this topic:
Page 1 of 1
Help
