After almost 12000 miles on my 545i I can honestly say that I love the SMG. I would love to have faster shifting (especially downshifts), but even in it's present form I would buy an SMG again if I were buying another E60 now. HOWEVER,......having said that I do occasionally miss the "feeling" of using a clutch and selecting different gears.....you know, the hand and foot movements involved in driving a manual. So I think there is a way to give us the best of manual and SMG transmission in one car.
First of all, in it's current state the SMG clutch operation, as well as the actual gearshifts are done by valves and solenoids. They get their commands when to "push in" the clutch and when to "shift the gears" from the computer, which issues those commands after receiving a command from the driver (paddles or gearshift knob). Each position on the gearshift knob (R, N, D, +, -) has an electronic switch that when activated sends a signal to the computer which then commands the transmission to do what is needed. For example, if the car is stopped and then we push on the gas pedal the computer commands the clutch valve to release the clutch and the car moves....then when we tap the paddle or the gearshift knob the computer commands the clutch valve to dis-engage the clutch, the tranmission solenoids to change the gear, and then the clutch valve to re-engage the clutch. The point that I am trying to make is that everything is commanded and controlled by switches and the computer, so the idea that I am about to propose "should" not be hard to implement by BMW, or even to retrofit by one of the high end BMW tuners (Alpina, etc.). Here's what my idea would be, tell me what you think:
I think they could add a clutch pedal to the SMG cars that would NOT be mechanically (or hydraulically) attached to the clutch slave cylinder, but instead it would electronically be connected to the computer. Think of the "drive-by-wire" gas pedals......well this would be "clutch-by-wire". It would have a high resolution encoder so as to provide true variable control over the clutch. In addition to that the gear shift knob/gate would be replaced by another unit that would have all the gears 1 through 6, Neutral, and Reverse in the traditional positions that the BMW 6 speed manual has. The only difference would be that just like the clutch the gear shifter would NOT be physically connected to the gearbox but instead a "shift-by-wire" shift gate that is connected to the computer. It would have switches in all the gear positions (1-6, N, and R) instead of the few that the current SMG has.
So here's how it would work. A button next to the gear shift knob would select whether you want to drive it in "SMG manual mode", "SMG Auto mode", or "True manual mode with clutch". If you select "SMG manual mode" or "SMG Auto mode" then you would use it just like you do the current SMG. However, if you choose the "True manual mode with clutch" then the computer would look at the input from the electronic clutch pedal and electronic gear shift knob to do what is commanded. For example, when the cluth pedal is pressed the computer would get the signal from the electronic clutch pedal and command the clutch slave cylinder to disengage the clutch the exact amount that corresponds to how far you have pushed the clutch pedal. Then you would select the first gear with the shifter knob and the switch in position 1 of the gate would send a signal to the computer to put the gearbox in 1st gear. Then you would release the electronic clutch pedal which would tell the computer to release the clutch slave cylinder and engage the clutch. Essentially this simulates the control and the "feel" that you get in a manual gearbox car. However, you still have the SMG option available whenever you want to use that.......the perfect combination as far as I am concerned.
I think this is a relatively simple change which only involves the inputs to the computer, the outputs from the computer should remain the same as they are currently. It only involves a couple of electronic input devices (electronic variable output clutch pedal, electronic manual shift gate) and software changes to look at and interpret the inputs. After that point the output or the commands issued by the computer to the clutch valve or gear shifting solenoids should be the same as they are now on the SMG.
I don't want it to seem like I am oversimplifying this, but at the same time to me it seems like a relatively simple addition to the current SMG setup without having to change the actual hardware involved (gearbox, slave cylinder, etc.). It only involves input devices and software. I think even a competent BMW tuner could do this, let alone the factory.
THIS would be the perfect transmission for me
What do you guys think?
Sign In
Register
Help
MultiQuote
