Amazing BMW 1602 Restomod Has Carbon Fiber Body and S14 Power
By: Brett Foote | January 24, 2023
A/C not working after LCI Climate control retrofit
Hi guys, I've swapped my High climate control on my '05 E60 with LCI one. I did the pin 21 "magic" and the electric fan stopped blowing with full s...
Reliable Furniture Transport Services
Moving can be a daunting task, especially when it comes to relocating furniture. That's where we come in. At XYZ Furniture Transport, we specialize in...
Hello friends, I have problem with winkfp, I try to flash MOSTGW but it stuck, in comfort mode when i choose my zusb 9185627 MOSTGW, it give me Hardwa...
I'm quite sure you need Icom and ISTA/P for this procedure as the FIBRE connector musy be present to programme the ECU
Did you fix it? Now i have fix it, no coding needed. The wire from car at pin #21, that one i moved to pin #14, and then solder a wire between pin ...
By: Brett Foote | January 23, 2023
By: Michele Lupini | January 16, 2023
By: Michele Lupini | December 6, 2022
By: Michele Lupini | November 26, 2022
By: Patrick Morgan | November 3, 2022
By: Michele Lupini | October 17, 2022
