Amazing BMW 1602 Restomod Has Carbon Fiber Body and S14 Power
By: Brett Foote | January 24, 2023
Differential Output Shaft Binding
So I just replaced both differential output shaft seals on my 2008 E60 535xi 5 spd N54 sedan (200,000 mi). When I seat the side-output shafts into the...
08 535xi my second dme fuse the 30amp keeps blowing, any suggestions on why and how to fix it? I put a 40 amp in just because i was curious and it ble...
I'm quite sure you need Icom and ISTA/P for this procedure as the FIBRE connector musy be present to programme the ECU
A/C not working after LCI Climate control retrofit
Did you fix it? Now i have fix it, no coding needed. The wire from car at pin #21, that one i moved to pin #14, and then solder a wire between pin ...
By: Brett Foote | January 23, 2023
By: Michele Lupini | January 16, 2023
By: Michele Lupini | December 6, 2022
By: Michele Lupini | November 26, 2022
By: Patrick Morgan | November 3, 2022
By: Michele Lupini | October 17, 2022
